Naughty Naughty Blue
  ClioI Ph.3 1.6 16V
Hmm, the F-block has 89mm cylinder spacing, the k-block 85mm...
I don´t think that the flange seals properly afterwards.
I did something similar, but I weldet a completly new k4m-specific flange to it...
And now it begins
so here is my solution
with the flange chopped a bit and it stuck in a vice, welded back up she fits like a glove
looks better too :eek:
  alien green rs133
nice work mate. and mine seals :eek:
  alien green rs133
[youtube]KU8mkPhQYrE[/youtube]
and she is running a little rich atm, ie flaming back through boddies :D
  alien green rs133
I don´t think that´s so much a problem of running too rich, more of that f****** or do you use something different at the moment?
what are you on about?
i know its running mega rich its running on a 240bhp map, as thats the base map i could get hold of, thusfor its filling the inletmanifold with loads of fuel and with the overlap on the valves it pops a little, and you know its way to rich as it fills garage with black smoke.
  alien green rs133
i been messing about with the ecu tonight, and instead of the fuel rows altering by tps i have set it to the ecu's internal map sensor and it is running alot smoother, but i think i have destroyed a lamda sensor... meh
  ClioI Ph.3 1.6 16V
I meant that double ignition of the stock ECU that often leads to back fire, or do you use something totally diffrent like supersquirt or so?
How do you think you destroyed the lambda sensor, by excessive heat cause of misfire??
  alien green rs133
im not using the stock ecu, i am using standalone engine management
and im also using wasted spark
  alien green rs133
Get a move on, Trax is coming up soon :rasp:
its roadworthyish
just polishing and ironing out fault and making it run 100%
rad fan needs to be controled via standalone, as cars ecu will let it get mega hot, but if you turned ignition off and back on the fan came on :S
so ill just have it wired via standalone ;)
goes well on full chat. but pulling away mid range is poor atm
ill get it sorted though :D
  alien green rs133
1st phail
engine mountain snapped clean...
FFS 9days deadline
getting my head round mapping, runs ok up to 5k ish
Tunst
  Focus ST225, Focus E
just looked through the entire thread was a good read :)
im a mechanic myself but i prob wouldnt be doing anyhting lke that anytime soon!
Electrics like that scare the S**t outa me lol.
looks awesome :p i want ^_^
  R5 GTT EFI Clio.
Great project thread mate, just read through it all seen all the pics and watched all the vids, what an inspiartion!
Well done fella!
  Glanza V
just read this whole thread and i have to take my hat of to you mate you have done a fantastic job! good luck in getting it ready for trax :D cant wait to see this at a meet :D
mark
  alien green rs133
manifold clears fine.
for some reason when i started it, it decided to run on 2/3 cylinders, revved it for about a minute and the 4th one finally sorted itself, i assume it just got choked up :S feck knows.
i got another trumpet mount to make and chuck the dash in and i should be drivable for trax :D yey :D
