Track phase 182
Picked up an AP racing bias valve the other day just need to bleed the brakes and go for a test drive, if that doesn't work, I'm gonna try taking two lines from the MC rather than blocking one port and using the other...
Logically this makes sense, of opening up both the holes so it spreads the braking effort out the cylinder evenly rather than just out of one port... but im not sure if that translates...
If that doesn't work I'm all out of ideas.
Scrolling through my insta and stumbled across the night the shell was loaded up on the trailer to be dropped at mine the following week!
To 2 days ago
Car looks great!!
How on earth do you jack your car up on a pebble driveway?? does it not just wedge into the floor when coming down?
I have enough trouble on an old crazy paving driveway!
Car looks great!!
Thanks bud
Yeah I have bought 2 x 8by4 bits of plywood to go over the gravel :)
Ahhh good Idea!!! Never thought about that. Might try it in future. Nothing worse than having to push the car back and forth just to find a big section of paving which isn't going to buckle the jack wheels
Yeah you can't really do anything safely on uneven pavement/gravel, Should of got marine ply though! as the ply won't last exposed to the weather all day.
All it needs to do is get the car up so you can get stands under it though, then you can just remove the ply and put it inside again until you want the car down.
Yeah go smaller than what I've got then, as mines for working underneath too, and as you can see in the pic once it's up on stands I can't get the wood out
Sooo ***** Brake update *****
So after installing the AP racing bias valve and having no success with that, I really really questioned why I was building this car, and questioned WTF was going wrong.
So I had a chat with my local Newbury specialists Andy Reid, and he said to not use the borrowed cup front lines and to make my own.
So I set about doing this, he also said to change what ports went to what brakes.
So the front ports went to the front brakes, and the rear ports to the rear brakes.
Welll I went out with cold tyres and it was raining it already felt so much better, it locked up but definitely a lot less than before.
So the reason why it set up how it was is because the orginal cup lines and m10 and m12 unions already fitted so only fitted in the specific ports...
What a f**king nightmare!! So hopefully with some warm tyres we should be all good on the locking up front...
Right, so still none the wiser with what's going on with the rear bias...
The car is pulling 14kg on the rear on MOT rollers... so the braking effort is reduced enough, for me to move the rear wheels with my hands when someone is stamping on the brakes.
It's not the handbrake cables snagging as the handbrake has been removed and it's still locking up.
I'm questioning whether it's just me on the brakes to hard, but in my old 182 (with abs) I used to brake a lot harder and sharper on track with no locking up, or activation of abs...
Anyway, skinned the bonnet a bit more - now she flexes [emoji48]
and I need a car cover, roof scoop doesn't like the weather...
also spent a bit of time on my mates 205 gti, always nice to work on something else for a change haha.
Well yeah bedford is looming at the end of the month, and the ideas of clamping the rear brakes lines, or removing some of the rear pad material surface area wise are going through my head [emoji85] #pikey
lol, any ideas please speak up, the worst I can say is that I've tried it...
205 looks cool.
You still running the hydro handbrake?
Im not no, i think the cylinder size was wrong, which i completely underestimated... when i came to bleed the brakes the handbrake would be solid, and the rear brakes would not retract... So its still in the car but not plumbed in, as I'm to lazy to remove haha.
How did you skin the bonnet so cleanly?
Angle grinder accuracy, its not really that clean... but it weights s**t all now! Which helps the back when lifting it off the car ;)
bashracing
Are both rear wheels locking?
I'm thinking you may have a seized shocker or a twisted axle that is unloading one wheel (like cocking a leg)
When heavy braking is causing a lock on that wheel
Just to add I would put the brake lines back in there original ports (diagonal split) as I don't fancy your chances of pulling it up with only 28kg of brake force if you have a front pipe fail
I don't know I don't have my go pro anymore to check! will have to get a mate alongside me... It feels like both wheels are locking.
well had a cheap alignment done
0.50 and 3.30 is toe on the rear... The axle is not straight...
NorthloopCup
What's the measured in degrees? Surely you'll see 3 degrees of toe in? it looks straight...
The offside rear is also bent so that might upset things a little...?
I work with Dunlop tracking sticks mate, so I'm not 100% sure if that's in degrees and minutes or in mm tbh. You should be able to see it, but it's hard to line it up on a Clio. You need something for your eye to line up on, and I personally find that quite difficult on a Clio. Not impossible though.
Was at J-Tech earlier. He said you'd rang about the braking issue.
Yeah, see if he had dealt with anything similar for the breaking problem... and was just getting a price on some alignment,, I might pop in and have a look at there m3 it looks awesome!
Cub.
It is an epic piece of kit. They're racing it this year and taking it to a few shows like Players etc.
Yeah very cool, what work did you have done today?
Took the misses out for spin today, it followed with "can I drive it" ...
"Sorry love seating position is bolted in, can't change it"
Just love being in it, went out on the direzzas and the car felt so much stable, you can definitely feel the sidewall flex on the toyos (some ditchfinders)
Turn in felt so much more sharp and outright grip was great.
So great I took some more photos of my car
Gorgeous looking engine, and what a sound. I want an rs4...
So not many updates have happened, but drove it up to Silverstone today to have a catch up with Anthony and took it as a good oportunity to speak to a few of the Tricolore lads above their caes/series - which they were happy to answer my questions!
Thanks for the biscuits Tony haha
So yeah Anthony was on a mission and I managed to get my car on some corner weight scales.
So this was before, very very happy with the weight of it (about 1/4 of fuel) (899kg)
This was after I think, the diagonals and rears suffered abit but the front weights are pretty decent. But Im happy and happy that we didnt spend long on it at all and take up Anthonys day etc
But yeah after discussing my brake situation the brembo kit will be up for sale, and I'll go back to standard callipers and going to have another look at the way I have layed out the MC as I'm now getting to much bias to the fronts even on standard pads.
Oh and the rear beam is perfect, f**k knows what happened to the alignment machine in a few posts above...
  Clio 172 & BMW 335D
Who's it with bud? and is there any space left?!
Just checked it's with Javelin, it says fully booked now may be worth ringing and going on reserve list.
Let me know if you do I have a garage booked
  Clio 172 & BMW 335D
@Mash. regarding the build have you cut out your door cards now you have plastic Windows mine are coming Friday, just debating what do with the door
Gutted just checked Ive got work that day anyway. As yes i would of phoned them up for sure. hey ho, you at bedford on the 27th? Renault and ford day
Yes bud still a bit more material i can cut out and drill some holes in the bottom flat panel to get a few more grams out of it... i think theres a post somewhere in this thread of how the windows are bolted in?
  Clio 172 & BMW 335D
Sorted how I am going to bolt my front windows in just debating cutting all the material out covering it up! My uncle work a window fitting company so he is going to do a decent job of the sealant on the backs!
Im not on the Bedford one its to far for me after the Oulton park trip
