Hi all!
Just wondering what you would choose if you had the choice between them, think they both work out similar prices (if you keep the RS tuner).
Also i fill up with 98RON fuel about 75% of the time but sometimes i have to use a station which has only 95, if i was to get the RS Tuner with 98RON map is this likely to cause any issues? I suppose if it would cause any i could plan ahead better to prevent this but sometimes the convenience at the moment means i dont bother!
Another question on the RS Tuner. I hear it stops lumpy idle etc, does this also include the cold map when you start off, i have to go up a slight hill to start my journey to work and the car is a nightmare for the first 30 seconds sometimes, very juddery and somedays will backfire loads when you let off the throttle, 30 seconds later it suddenly stops and is fine, will this stop with the 98 map?
Thanks for your help
