Dave3141 said:should be between max and min markers, chances are your car is just over fueling, running rich at start up.
Not sure if its a problem though.
JuanBoy said:Won't be nothng to do with your oil reading and a little over the max mark wont do any harm. Just sounds as if it's running rich - get it back to the dealers and ask them to get it tuned. Where is the wet patch on the exhaust exactly, on a join?
Sminp said:wet patch is on the ground below the car, it appears everytime the car has been on for about 5 mins
maybe its just pissing condensation as the exhaust would have been cold when the engine is turned on?
butch172 said:sound like a fuel leak from the tank sender unit mate, what mark/shape is ur clio?
butch172 said:too much oil in the engine would not cause a petrol smell, the liquid under the car( if its at the tailpipe end is probably water caused by the catalyst and if its nearer the front its from the air con) lift the rear seat base on the drivers side and remove the black sender cover to check for fuel leak from tank. 04 is still under warranty so let renault sort if out m8!!
Sminp said:Whenever i switch the car on, you can smell petrol outside , i think there is too much oil in the engine.Is this a bad problem?
