Is you clutch creaky?
ripp
  182 FFAT
I am sick of this annoying issue and I'm curious just how many people have it. maybe this is not such a popular problem after all. I'm thinkin if there is some 1*2 with 100k on the clock with no creaky clutch then maybe there is a catch and the unlucky ones could sort it out somehow..
I'll start:
creak: yes
mileage: 62k
clutch changed: yes, at 50k
fork greased, clutch cable ok
thx!
  Ph2 Clio 172
Yep.
106k, no idea how old the clutch is. Does it on an off all the time, but increases after a 'spirited' drive.
  PH1 172
mine only creaks after being on the track, normal driving is fine, but coming into to pits after a good sesh on the track it creaks like mad
  SEAT Ibiza SC FR
Same story for 90% of the guides I find. Tigger, can you pester some admin to get to the bottom of it?
  "Navy" N17 TWO
I PM'd the OP of the guide a few weeks ago but haven't heard back yet.
Not sure if Admin can re-source the photos if they were linked from someones Photobucket or what-have-you.
ripp
  182 FFAT
greased the nut-fork joint couple of days ago and also tried to reach the fork-release bearing area with some degree of success and it was good for 2-3 days. Obviously in my case it's not a clutch cable issue.
I'm thinkin if there's a way of re-designing those contact areas or modifying them.. Any engineer around? :D Is it really that hard to get rid of this stupid fault?
  Clio RS 182
Yep mine creaks, either on a hot day or when i've been in a slow moving traffic jam where i've been on and off the clutch alot. mine is on 42k
I dont think there is any confirmed cure for this problem yet.
ripp
  182 FFAT
no there isn't
The car feels soooo much nicer without the creaky clutch :( Driven mine 5 years like that without bothering too much but now somehow it really bugs me
  Clio RS 182
no there isn't
Probably because its been pretty warm the last few days, therefore it'll be worse!
Darren S
Always gets worse when the weather's hot. In winter I don't think I ever get the creaking noise.
Started happening on mine about 30k ish. Had the clutch replaced along with the 84k service and all was silent. Put on 1,200+ miles during the Scotland road-trip and by the time I got back, the creaking had returned.
Tried greasing the cable and the forks, etc in past but it's always been a really short-term measure which I CBA to attempt to fix anymore.
As mentioned before, I wonder if the left-hand drive RS's suffer from the same creak - given the fact that their footwell's and the clutch are literally a few inches apart?
D.
  Clio RS 182
D.
any french on here
*stupid question is stupid*
davo172
  TCR'd 172
Yes did at 49k changed cable now on 63k aint done it since .(rushes off to touch wood !)
  "Navy" N17 TWO
^ Isn't a 172 though Kerry - probably easier to spot your clutch cable than your engine in the bay lol ;)
  172 Ph1/Scooby MY00
Yep, creaking has returned on mine - 160k. Clutch changed at 140k with new cable fitted = fixed (temp). Fixed again at 155k by greasing the pivot point under the rubber cover (air filter off, cable off end of fork, remove cover and apply grease carefully). Creaking came back again. I blame dust.
  2003 Clio 172
FYI, it was my guide that Tigger mentioned but I didnt re-post it as my creaking came back and i just live with it.
Musing with a cable replacement though as well as looking at the bushes in the pedal itself.
heat seems to be a very common cause with it and in my opinion, that shouldnt be affecting the clutch release bearing.
It HAS to be cable or pedal busing related.
Any clutch cable guides?
J
  172 cup- suzu rf600r
I followed jinjur's guide, used a liberal amount of motorcycle chain grease, that was about 15k ago and I havent heard a peep yet, even if you had to do it more often though it's hardly a big job.
I used quite a lot of grease, took the cable off and pushed the lever over for one side and reconnected the cable and got a neighbour to step on the clutch pedal for the other side, as I say no problem since and mines was constant/loud as soon as the engine was warm
  2003 Clio 172
Im still of the opinion this is cable/pedal related and that all greasing does is lighted/smooth out the load ever so slightly.
im sure the engine being warm wont affect the innards and lubrication of the clutch release bearing
J
