New MOT Additions (ATTENTION: All with removed headlight washers!)
  Ph2 Clio 172
From January 1st 2012 there are some additions to the MOT test. They are:
Headlights:
4.1.4 Compliance with requirements:
(a ) Lamp, emitted colour, position or intensity not in accordance with the requirements
(B ) Products on lens or light source which obviously reduce light intensity or change emitted colour
(c ) Light source and lamp not compatible
4.1.5. Levelling devices (where mandatory):
(a ) Device not operating.
(B ) Manual device cannot be operated from driver’s seat.
4.1.6 Headlamp cleaning device (where mandatory):
Engine Control:
6.1.9 Engine performance:
(a ) Control unit illegally modified.
(B ) Illegal engine modification.
4.11. Electrical wiring
(a ) Wiring insecure or not adequately secured.
(B ) Wiring deteriorated.
(c ) Damaged or deteriorated insulation
Airbag and seat belt pre-tensioner systems:
7.1.4. Safety belt Pre-tensioners:
Pre-tensioner obviously missing or not suitable with the vehicle.
7.1.5. Airbag:
(a ) Airbags obviously missing or not suitable with the vehicle.
(B ) Airbag obviously non-operative.
7.1.6. SRS Systems:
SRS MIL indicates any kind of failure of the system.
Most of these are of no real worry, however, this bit is:
For years there have been people trolling the internet telling people who have HIDs and remove their washers that there cars are illegal or will fail their MOT. This is simply not true. There is a requirement for car manufacturers to fit washers to cars fitted with HID headlights when produced, but the presence or functionality of these washers has never been part of the MOT test, or a legal requirement. Removing HID washers is perfectly fine.
However, this will change come 1st January. The Mandatory bit in the addition presumably implys that it is for those cars who were mandated to have them when manufactured, i.e. all RS Clios with HIDs.
Therefore, from 1st January 2012 Clios with the HID headlights and washer blanks fitted to remove the washers will fail their MOT's. Its a right bummer for me, as I still have mine fitted, they just don't work :(
  big boost cup
What about this part then
Engine Control:
what is classed as illegal engine mods
Sir_Dave
ClioSport Trader
7.1.5. Airbag:
Hmmm, i have harnesses & a steering wheel with no airbag.
Two crates of Stella on the passenger seat this year then ...
Scrooge
  E55 AMG
I like the kind of MOTs where the car doesn't even enter the testing station
eBay chip I reckon unless they have some new obd program to check if it has been re-mapped but tbh I don't reckon they will look that much into it.
Remember this is not supposed to add any extra time to the test so they won't be in depth checks
  Ph2 Clio 172
The trouble is most of the new points are really ambiguous. The headlights one is easy, if they should be there and there not, fail. Most of the others are proper grey areas.
However, the ECU and modifications ones are likely not to do with remaps. It looks like these are replacement ECUs or mods to the engine that mean it falls foul of EU regulations (usually to do with emissions). Remapping and fitting a new air filter aren't going to be a problem.
I'd wait till VOSA officially announce this tbh.....unless someone can provide a link to it on the VOSA site?
  Ph2 Clio 172
Its been under consultation on the VOSA site for ages, closed on the 27th May. I assume this is an early leak of the results of it.
For clarification, illegal mods are mods that are (unsurprisingly), illegal. It is not against the law in the UK to fit different air filters or remap your ECU, so they are fine. Infact, there is very little you can do to an engine in the UK that is against the law (if anything at all). This is different in other EU countries, and the wording is being standardised across Europe.
The ones that may be an issue are the washers, and the seatbelt/airbag rules.
Fletcher
Engine Control:
I've heard that supercharging a Clio will also be a instant MOT fail ;)
Good job my headlight washers are reet then :approve:
Gally
Lols I won't even mention how my emissions test went on my last MOT!
Ah the perks when your Dad runs the workshop...
  Lionel Richie
so the dynacup is knackered then, the ABS was thrown in the bin ages ago LOL
isle of man registration it is then ;)
Inappropriate suspension repairs or modifications..............
Low's gonna get you a fail. At least Gally will be safe :cool:
  Freetrack&Monaco 172
This is on overclockers
Looks like I might have to sort that knackered CV gaitor i've had for a while.
I had my Cup fail on its O/S/F gaitor in Feb as the larger retaining strap had failed (I knew it was loose before I even took it to the garage with my own pre-MOT-whatsmycargoingtofailonthisyear check). I thought "hang on thats not part of the test" but it is on the VOSA system as my fail certificate had the reference to the 'rule' it failed it on. It may just have different wording for the new test maybe?
  lift number 1 @ btm
Dunno, but if you charge £20 per car and pay him £5 you'll be able to have a nice holiday!
  Ph2 172 MB 77/468
mmm, well, my headlight washers have been removed and smoothed over, so thats one thing not to worry about
the cars a shed.
think i may be resitering it at my folks place on the Isle of Man as well then!
  Saab 93 Aero Wagon
Gaww Damn.....I'd be gutted if I didn't have a friendly MOT tester to hand...;)
The Cup would currently fail on:
Decat
No pretensioners
No drivers airbag
MIL on for said missing airbag
And probably a whole raft of other things these Euro fat cat health and safety, environmentalist, tree hugging, car hating, huge bonus earning 'I sit down to pi55' cretins want to deem 'unsuitable'.
