Valver rear wheel bearings
Has anyone got any hints or tips for replacing rear wheel bearings on a 16V? Going to tackle the job in the next week, getting a bit noisy!!! Do I need to remove the caliper to get the hub off? etc....
...know someone with a hydraulic press to get bearing out of hub so no probs there. Is getting the hub off easy?
PM Paul16v. I think he just changed his the other day and said it wasnt that hard. Im sure hell be abe to provide some handy hints, and he managed it without a press...
  Clio 190bhp Hybrid
Rear disks come off OK, Think I had to move the caliper obviously to allow the disk to come off, then bearings are inside the disk/hub as one unit.
Wasnt difficult. Replaced with new disks and bearing were pushed in using a manual press but it will obviously be hearder to remove and replace bearings as you have to be more careful not to damage anything when removing the old ones. Id pay the 20 quid or so and get new rear disks to save the hassle of bearing removal and have shiny new rear disks. Only hassle thenis fitting the new bearings.
  clio 20v
if u get valver rear discs from reno they come with the bearings already pressed in, there not too expensive
but u have to ask for discs for a car with ABS even if u havent got it but it doesnt matter either way
the non abs discs are dearer and come without bearings, work that out lol
adi
  172 & LCR
Buy new rear discs from Reno they come with new bearings already fitted and not dear, make life easy.
  172 cup,s2 rs turbo
still about a £100 aernt they.got some for a 5 turbo(same as clio) and they cost about that and that time they came without bearings
  clio 20v
nope cheaper than that if u ask for valver abs discs they come with bearings and are about 40-50 quid if i remember rightly
adi
  Titanium 182
mine needs new rear discs, and pads
does this mean il hae to change the whole lot, as the garage say no u dont do it like that?>
not sure if so il want new bearings
