Stud and nut info
  172 Rally Car
One thing I will say that's negative for the pms kit : who the hell owns a 5.5mm Allen key? Or 7/32's in old money? surely 5mm would have been better!
  182/RS2/ Turbo/Mk1
Lol I had a couple lieing around but I'm old.
5.5 makes sense as it can handle about 20% more torque than 5mm so less likely to round and 6 mm wouldn't really have fit properly without it getting thin walled.
He should include one when sending them out though I guess!
Jekyll
Ive been toying with the idea of adding spacers but having a look at so many threads on here im now confused lol.
Im looking at getting either 15mm or 20mm spacers and would ideally go and get a stud kit. What length studs would i need for those 2 sizes? Also i take it that what ever nuts i decide to use it wouldnt make with the stud length?
And lastly is hubcentric spacers essential? I use my car daily but probably will never see track use.
  182/RS2/ Turbo/Mk1
The pure kit will take a 15mm or 20mm spacer.
Yes you want hub centric. Don't confuse hubcentric with bolt to hub though. Different thing altogether.
  Ph1 T
I've got 25mm hubcentric on the front and 15mm extended bolts on the rear mate
From what chips said the normal size studs from pm will go into the spacer on the hubcentric and on the rears go into hub and spacer then wheel just slide over and nut on
  220 Trophy
For anyone that's interested I've ordered a new set of matching 30mm front / 25mm rear spacers so will have my Eibach 25mm front / 20mm rear spacers available soon. These are to be used with a stud kit, the front spacers accepts studs and the rears slide over studs already screwed into the hub
Jekyll
Yes im getting that muddled up with bolt to hub type :eek: So do I need a bolt to hub type or can I get away with the longer bolt type if the bolts will be replaced with studs?
Also I was on prima racings site last night. Are they studs decent? They sell them individually.
http://www.primaracing.com/PriceList.aspx
I take it its 80mm ones to run 15mm spacers? Sorry for the many questions and lack of knowledge on this!
  182/RS2/ Turbo/Mk1
Yes you can just slide the spacers up the studs if they are long enough, you dont need bolt to hub and in fact in the case of 15mm I cant personally name any bolt to hub type I would be happy using, the only ones Ive seen I would be worried about the safety of due to the lack of material present at the key points for strength under the bolt heads.
Jekyll
Ok that's helpful chip. Ill look into the extended bolt type but replace the bolts with studs all round. Its my daily so its just gets the odd blast and will probably never see track use, but my TPI polarised bolts are all rusting hence why im looking at a stud kit.
I run the wilwood setup and they dont have any disc retaining screws so is a nightmare trying to line up to get the bolts in everytime i take the wheels off. Stud kit is much easier tbh.
I know people are mentioning a lot of the pure motorsport kit but i was originally looking at some fancy nuts so thats why i posted up the prima racing studs as i wanted to know if it was an equally good but cheaper option if people didnt want to spend £130 and then more on nuts.
  182/RS2/ Turbo/Mk1
Pure will sell you just the studs without nuts if you want to add your own fancy looking ones mate.
But obvioulsy you will need to measure up for clearance before ordering the nuts.
  220 Trophy
Bolt the front 25mm spacer on then the studs screw into the front spacer, and on the rear the studs go into the car as per normal then the 15mm spacer just slides over them.
I run my PM kit on the turbo that way on the front as I have 30mm spacers.
Hi Chip, I've been let down by DAN@MAD on the new spacers, where did you get your 30mm spacers from please? - I cant seem to find them anywhere on t'net. Thanks Mark
  220 Trophy
I dont remember now mate, just whatever google brought up at the time.
They are these though:
http://www.carparts-tuning.co.uk/en...or-Renault-Clio-Typ-B-C57-3-Typ-R-tuning.html
Hey Chip, I've just ordered a set of 30mm spacers using the link you kindly provided. Quick couple of questions please - the PM studs only need to be tightened into the spacers by 20 NM, but what torque do the bolts that fasten the spacers to the hubs need to be tightened to? and should I use any Threadlock/Studlock? Thanks as always, Mark.
  182/RS2/ Turbo/Mk1
Don't think there was a data sheet with the spacers but you could email the seller I guess. Personally I just torqued them as if they were normal wheel nuts.
If you aren't taking them on and off often a thread lock would be a good idea. I've done mine dry for now though as in middle of developing a big brake conversion.
  220 Trophy
Thanks Chip. I enlarged a photo of the supplied bolts on the FK page and they appear to have 10.9 stamped on them which would indicate they should withstand the normal wheel bolt torque of 105NM. I seem to remember JMS also saying this a few years ago when they first fitted them. Will use some threadlock then as they wont be coming off for a while.
I still find all this very difficult to understand
PMS say there studs will only support up to a 12mm spacer but then chip says 15 and even 20mm is fine
I don't want to fit 25mm bolt to hub spacers to find they rub at the front but I also don't want to buy a stud kit and then find I can only fit 12mm spacers lol
We need a thread where people just put what spacer/stud kit they are running
I agree the 15mm bolt to hub look dodgy though - not a lot of material considering it's only a 4 stud wheel and the forces it will be encountering on track
  182/RS2/ Turbo/Mk1
Phil. I am saying they are physically long enough to take the spacer, so you dont need to go any longer.
However what I am NOT saying is that that ANY spacer of 20mm should ever be used as a slide on fitment, what Pure are no doubt saying is that if you go over 12mm then the amount of exposed thread is approaching 20mm, and thats all they are confident they can cope with before it becomes an issue.
If you are running 20mm spacers, you have an inch of exposed thread to stretch, thats going to be a lot of length gained when they get hot, which means the nuts will loosen, I would personally recomend at that size of spacer that you swap to a bolt to hub type instead.
Ahhh got you - I assumed they were saying they literally weren't long enough - but no I understand the risk of them heating up and stretching and working loose is high
I think I'm going to go with some 25mm bolt to hub spacers with the PMS stud kit - I just need to be sure the 25mm won't rub
But I can always crack some more negative camber on - as with the KW V2's if I put full negative camber on the wheel hits the springs lol
I'm just not sure about the MAD spacers being made of alloy - the 25mm bolt to hub spacers sold on ebay are steel which seems a bit safer to me
  220 Trophy
The rear 20mm spacers I'm taking off slide over the PM studs and I've had no problems. I'm increasing these to 25mm so am going to fit spacers that bolt to the hub and then the studs screw into the spacers. There are a multitude of different spec OEM Clio suspension set-ups and wheel offsets, but on my OEM F1's I wouldn't be able to run 25mm spacers on the front without I'm guessing -2 degrees camber. I'm running -3 and still have a bit of clearance hence fitting the 30mm's.
The Eibach and H&R spacers are all alloy.
Ahhh cool cheers mate - I run 2118's in the ET43 offset so they sit 5mm further in than normal wheels anyway - and I'm running -2.75 of camber
So 25mm front spacers should be fine
  220 Trophy
I think you'll be fine then. I think my original OEM F1's are ET43, so you must either have wider track suspension or wheel offset from standard for the 43's to decrease the track width. Like I said, there are a multitude of different OEM set-ups/offsets.
  220 Trophy
I think the actual mechanical suspension track may be wider on the Cup, but then this is allowed for by having less offset wheels. If you have fitted PH1 ET43 wheels then you have actually increased your total track width. Which isn't a bad thing but you will have to keep an eye on clearance. Theoretically you now have an extra 5mm each side of track width that me (without spacers), but I'm going to be fitting 30mm spacers so you should end up being be identical with 25mm's.
I'm so confused I thought the higher the ET the further in they sat
I was definitely told when I bought the 2118's that they would sit further in
There's at least a 15-20mm gap between the tyres and the outer arch - the wheels on the back actually scrub the inner arches
  220 Trophy
Yes sorry you're right, I got myself all mixed-up there!! The less the number offset the greater they will stick out from the hub. So you will have reduced your overall track width by fitting the F1's but can then make this up by fitting the spacers.
EVOgone
  Pink Cup Racer
Interesting i have 15mm spacers on the front of mine and the PMS studs are no where near long enough. Will be sending them back and getting some 100mm long studs.
The quality looks go though so bit of a shame. Plus the cup racer run mutli thread types so will get some studs that have M12x1.25mm thread so i dont need new nuts.!
  220 Trophy
My 20mm non-bolt-to-hub (Type A) spacers will be off the car this weekend if they're any good to anyone else? (FYI Type B spacers are the bolt to hub version)
I was running these on the rears and there was plenty of the PM studs left.
  182/RS2/ Turbo/Mk1
Evogone, maybe your wheels are thicker at the point the stud goes through?
Or you have ally brake bells which are thicker?
​Either that or yours must be different length studs to other people's somehow.
EVOgone
  Pink Cup Racer
Speedline Turini Cup racer ET43 and maybe the bell is thinker slightly but there no where near enough thread where i would be confortable with using.
  220 Trophy
I've got Alcon 4-Pots with seperate bells & rotors and as far as I know the bells are not any thicker than normal and the studs dont look to screw in any further.
EVOgone
  Pink Cup Racer
Do you run 295mm discs ? as my caliper wont fit without the spacers. Ifi ran a 280 mm disc then i could possibley run with out the spacer.
  220 Trophy
It's not clear if you mean if the calliper will hit the back of the spokes or the inside of the wheel. There are so many permeations that I think its all trial and error. I used to run 295mm rotors with my old Willwoods but could only fit 290mm (I think) rotors with my Alcons because the calliper is so much larger. Even then there is only may be 2mm gap between the calliper and the inside of the wheel. As to clearing the back of the spokes I think I had the 25mm spacers fitted at the same time as the Willwoods so I cant comment either way.
  182/RS2/ Turbo/Mk1
Spacers effect clearance on the inside of the wheel too, as the outer edge is a smaller diameter than further in, the only way I get away with Tarox 6 pots and 300mm disks is that I have spaced the wheel out far enough to get me away from that smaller diameter outer rim.
I dont think I could get over 280mm with the same calipers and smaller spacers, not cause of the spokes, but cause of the outer rim.
  220 Trophy
Thanks Chip, as always yes you're right, at least on F1's as they have a raised lip just behind the spokes. I've subsequently had to fit the wheel weights right on the outside edge of this lip just behind the spokes as otherwise they were clipping the callipers.
