Oil drain plug rounded HELP
  clio 1.4 16v 02
Just got all prepared to service the clio and the effin sump plug is rounded, seriously rounded! how the hell do I get it out? mole grips wont work and I dont have vice grips :(
  Renault Clio 1.2 16v
Drill it out like a boss.
*DISCLAIMER*
I take no responsibility for any 'mishaps' that may occur...
  Clio III 1.2 16v 06
Try a kit from trend, about 15 quid one side drills a hole the other is a screw type thing but with reverse thread do when it bites, it will turn your plug too
  clio 1.4 16v 02
100mill syringe and a piece of tube down the dip stick hole.. 2 hour later zzzzzzzzzzzzzzzzzzzzz
  clio 1.4 16v 02
had a go at smacking it round with a hammer and chisel and a hammer and flat head.. just takes chunks out of it, hence why I asked if the bung is steel or alloy :(
  SQ5
you know its a square hole ur not thinking its like a normal bolt you use a spanner on are you?
I'm well aware of that, but to have a hole you need a surround, hence the lovely round surround around the square hole that you put your mole grips on
