182 Trophy
I posted a while ago (about october time) regarding an annoying whistling noise but only above 3k rpm, which turned out to be the exhaust manifold/cat joint. The sealing ring had slightly perished causing an air leak. I Replaced that & all was sorted.
Recently this noise has starting to come back & is progressively getting worse. Im sure it cannot be the sealing ring again, so I was wondering if it was anything to do with the spring bolts that could be causing the problem. Any ideas?
