ph1 172... Sold:(
On Sunday evening I noticed a very slight 'clunk' when bringing the clutch up and the front wheels took load, coming from what I then thought was the passenger front wheel.
The sound was very slight and whilst it has not increased in volume or harshness, it has become more frequent, occuring when shifting from 1st to 2nd at very sedate speeds and no matter how much I finesse my clutch it is there for every flat/uphill start, and also now when coming gently to a stop, at the moment the car actually ceases to move, although it doesn't occur with more aggressive stops.
Driving and breaking are normal, straight line, no pulling. However by the time I'd got home from work today I'd decided it was concerning me enough to have a look so I jacked her up and pulled the front passenger wheel off to take a look.
Leaving the car in neutral and manually spinning the hub and disc revealed a small amount of play, along with the clunk which sounds as the play is taken up.
It occurrs spining the wheel and driveshaft in both directions, and the spinning motion is still smooth and free and easy. No grinding or grating or further noise.
Using 2 hands to pre load the disc/hub against the driveshaft has eliminated the problem from being in the hub assembly, so it's coming from where the driveshaft inserts into the gearbox. When you get close you can tell that's where the noise comes from.
Eeek
So it could be the UJ/CV/Lobro (I don't know what type of joint is used here) or it could be something a bit more hidden in the diff/output drive (although if that were the case I'd be inclined to expect the noise to occur centrally rather than being so obviously from the one side?)
Anyone had any experience of failing driveshaft joints, and does any of this sound familiar?
How long can it carry on without being an 'issue'.
My wallet definately can't handle the gearbox needing work so if you could keep your answers on the cheaper side it would be really handy![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Car is a ph1 127, Y reg.
Thanks in advance.
S.
Eeek
Thanks in advance.
S.
