Fixing Stud Conversion Kit....
  FF Clio 182
Purchased a stud conversion kit from M.A.P.S on eBay and just have a couple questions when it comes to fitting.
1. When putting the studs in do they only have to be done up slightly not torqued to a high spec ?
2. I assume you use Loctite but should I use Red or Blue ?
3. Once they in do I just torque the nuts up to the standard 105nm ?
  FF Clio 182
Lol snap....
I seen that but wasn't sure if it was a "universal" sort of things
Red Loctite or stick with just blue? I know you can get a specific Loctite for studs
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
You need to use a stud lock NOT a bearing lock (as that shiz is structural).
