This is '51' Clio 1.2 Dynamique as it stands right now with its first couple of mods. I'm not going for the usual route with this car (i've got a Vrs for that ) but instead I'm trying to increase the economy of the car without ruining the aesthetics of it.
First up was a new route for the feed pipe to the airbox. I simply routed a small hole through the plastic sheet behind the grill and fed a duct pipe through. I can post up some pictures if anyones interested.:boring:
Next up, which I did on friday night, is the wheel deflectors. most modern cars have these fitted nowadays, so I figured it must be worth a try on my car. I have yet to test these but I do expect a small increase a higher speeds.
Thats were I'm up to at the moment. I no its probably not as exciting as the stripped out cups but this is the route that I have chosen. Next up will be rear wheel deflectors and passenger wing mirror removal. If these ideas work well I may consider marketing them!!
