Clock dim wen lights off, when lights on no clock :S
jaysmith
ey up im hoping someone can help me my clock is dim when my lights are off as soon as my lights are on i carnt see the clock ive replaced the clock 2 times and no difference. its really confusing me lol. jay
when i was doing my fog lights i accidentally pulled the resistor off the blanked dimmer switch plug and it did exactly how you described, might have something to do with your dimmer switch
EDIT --
As soon as i put the resistor back on it worked, (i went on to get a dimmer switch and worked perfectly).
The little panel next to your steering wheel where the headlight level switch is, get a credit card under the bottom edge and pull the whole little panel out, its not hard to do. Then you should have a blank wire with a black plastic thing on the end (resistor). Give it a wiggle / pull it off blow it out, put it back on and see if that works. I ended up buying another panel with the dimmer switch on because its a feature on the car that isn't being used.
The dimmer switch is a switch that allows you to dim the dashboard lights when the lights are on so you can set how bright you want them.
