Clio 182 track car info help
  2004 clio182
Hi guy I'm new to this forum I am after so information for mounting my harnesses in my car I have already mounted my shoulder straps around harness bar , and door side into existing seatbelt mount but I am struggling with the best place to mount handbrake side , any help much appreciated
mikekean
  996 C4S, 135i, E30x2
I wouldn't use the mount on the sill for the eyebolt, if you grab your harness strap and pull straight up on it you will see the sill flex. The eye bolt creates more leverage than the standard mounting bar, It is only sufficient with the standard type seatbelt as the load is spread across two points and with much less leverage than and eye bolt. Drill a hole through the floor for both mounts and put a spreader plate on the back.
