bulkhead drain holes
  1.7 cdti
it would appear theres water collecting in my passenger footwell and wondered if there could be a blocked drainhole in the bulkhead as there seems to be a little damp behind the glovebox . all help would be appriciated
  M3, Cup racer'd 182
You'd probably find it's the one in the front/center by the heater fan.
If you feel around the bulkhead near the right hand side of the exhaust you'll find a rubber tube, another forum member was having this problem untill i located it.
Because the the pipe was blocked the water was gathering up and seeping through the heater fan seal and soaking the carpets inside.
