Bleeding Brakes After Trackday- Just the Dirty Bit or All?
  Clio 182 FF
Hi Guys
I had boiled the fluid on the trackday a month back and bled the fluid at the weekend. However I only bled the dirty fluid and didn't flush it all through as I have done previously. Do I need to flush more than the dirty fluid after or will this be enough?
Steve
  ST3 8.5
I just drain the calipers, nothing else needed.
You will be surprised how hot decent pads & fluid get, I was :D
Pyrometer FTW.
  R5gtt, 182, volvo...
Pointless... Brake fluid is hygroscopic, once opened its attracting moisture so should be used or binned...
If you're bleeding just the lines and storing the rest, you're next top up is a fail upon a fail upon a fail...
Ok, your experience might be ok doing this, but it's poor practice, even more so if your hitting the track and want the car 100%
