ABS, TC and Serv light
fil_b
  172 FF and Fabia VRS
I had a search and cant seem to find an answer
Near enough every drive i do i get these light come on
When they do come on
TC - dont work
ABS - dont work
What is the cause as no1 and searches i done - no1 can say (alot about abs ring?????)
Used to come on once ina blue moon but now its "VERY" regular and i getting lil worries
Noticed a couple of times, they come on when i drop back into 3rd
Please advise
tar
feebs
  182 Clio
mate had exactly same on mine, changed the pads and fluid and stopped comin on for all of two weeks!!! jus taken it to renault had it dyno'd they came back with everything is workin fine until that sensor comes on, they have put it down to a dodgey wire or loose connection somewhere!!!! goin in 2 be sorted next week!
  RB 182FF, Saxo Track Car.
Brake pedal sensor.
+1
I did a search the other day and it will come up, I searched as I had the fault. Plugged a diagnostic machine in and it came up brake pedal switch.
Out of curiosity, does it go off one you switch the engine off?
  Clio 182 Mondeo Ghia Est
+1
I've had the same prob several times under warranty. The brake pedal switch was replaced and when it came back it was put down to the actual adjustment of the switch (2 different dealers). Hasn't come back since:D
