Hi there, hoping some can give me some light.
Last night my car started with a knocking noise, yes another, as if it already hadn't had enough!!! Well, the noise is as follows. If the car is in gear (any from 1 - 5) and release the gas pedal you will hear a clunk/knock form the front of the car (left side), then if you put the foot again the same clunk noise will listen. The same noise also happens if I pull away, then put the car to neutral and go on the brakes, I though this could be box/shafts related, but the car does it in neutral, what could be wrong?
The knock noise isn't load related, no matter if I do smooth or rude, same level of noise in same situations. Car does no grinding/wiring/whining noise at all when cruising at any speed, in/off any gear
Comments?
Comments?
