I really want to solve the knocking noise from the suspension top mount (I guess it is where the noise from), but not sure which part I need to change. Can someone post a diagram from the dialogy or real pic of what I need to change??? The whole top mount unit?? Or bearing washer???
The noise is getting more frequent now :-(
Also, I want to know the difference between knocking noise on heat shield and steering knocking???
Attached are 2 pics I found, not sure if they are for 172. So, which section do I need to change??? I add some copper grease and problem not solved.
Really look forward to hear from any of you, best regards.
