itll look better if you lower it, but the lower you go the more likely to rub it is. most peeps will suggest 40-60 mm as it wont look low enough if you drop it 30mm. as for width stick with 7j or at the most 7.5j, but the offset is also a major factor on whether they will rub or not. style of wheel is personal really so just get a load of magazines and see what styles you like
