Wet and dry
Someone posted a wet and dry guide in the past, but it was a bit long winded.
Can someone give me a few basic steps on how to do it and what to use, please? Pics would be cool also.
Purchased some 1500 grit from halfords today.
Did you use all the steps on the above link?
I just have a couple little stone chips I need to take care off.
  106 GTi
Build up the layers of paint over few days till it gets level. Nice and thin, don't go mad and do it too quickly.
MRBILLYUK
  FF Jeden Osiem Dwa
I used 2000 grit wet n dry , build the paint up with a cocktail stick so its slightly proud then rub it down so its level , let the wet n dry do the work , no need to apply lots of pressure , then megs scratch X to polish it up afterwards .
MRBILLYUK
  FF Jeden Osiem Dwa
Try and keep the area you wet n dry minimal , obviously if the area to sand is only very small i.e. a small stone chip the surrounding area will be sanded as well . Patience is the key word when layering the paint and sanding .I'd leave it a couple of days after touching up before sanding .
