White Evo V
Since I got my car the washer jets on the front just tricled out and never were powerfull enough to clear the windscreen so today I set about sorting it. I took the scuttle panel off and took both motors out and connected them to the battery and both worked fine. Plugged them both back in and just one worked - the one closest to the wing on the side off the filler bottle. So i thought it must be because it needed both motors to make it more powerfull and one didnt work so I thought it must of been faulty wiring and decided to connect both lives and earths on the working motor to the live and earth on the non working motor - this was before I found out the non working motor was for the headlight washers. Ooops! Now non of the motors work and the climate control doesnt work but no fuses have blown.
Could this be a relay???? if so which relays are for the windscreen washers and climate control panel?? Thanks
