Upgrade to Espace (2 Pot) Calipers
  172/1.2/E30
Re: Upgrade to Espace (2 Pot) Calipers -> Wich discs ?
Ok, thats makes it official -> Mtec ones off my list.
There are also Zimmerman (German Quality) ones i only have to check what they cost and what the part number is.
Stay away from Zimmermann crap. They crack between the holes aswell. Not made for use with performance pads aswell.
  MX5 NC 2.0 Sport
Ok good thing i ordered the brembo's then :approve:. Allthough i always thought that Zimmerman was pretty high quality .....
  Cup In bits
Seen this long time ago from Noos but decided against when I couldn't find good pads and also I think you might run in to issues with the offset of the disks, may need to space out calliper from hub. Good luck !
  MX5 NC 2.0 Sport
Exactly i linked to his article in the 1st post. In his topic though its clearly mentioned that its a direct fit so im assuming it is, but if a few spacers are needed thats not a real issue ;). I'm aware that there aren't any realy high performance/track worthy pads, but this is only a concern if you track it or drive it like its stolen 24/7. I don't do both so for me some brembo discs/pads will be a major increase in stopping power and more than enough for some hard driving so now an then.
How you getting on with it smokey??
G172 can do brembo discs and pads for circa £130ish posted (uk)
George shall update and confirm prices.
  MX5 NC 2.0 Sport
The exact same setup (Brembo pads/discs) is on its way to me as we speak (should be here friday).
I can confirm if the pads fit that evening, fitment of the whole setup probably saturday.
  182
Cool keep us updated. If all goes well i shall get ordering.
  MX5 NC 2.0 Sport
Sure will keep you guys up to date during the entire process.
The pads i ordered are these : http://bremboaftermarket.com/En/Car_Disc_Catalogue/Catalogue_Detail.aspx?ApplicationIDMaster=20336
Part number : P68026
According to several websites and brembo them selves these should be correct (dimensions are spot on aswell).
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
That' the right pad part number for the mk3 Espace calipers.
Let uk know how you get on fitting everything when they arrive Smokey.
cheers
  Turbo 182 Alfa 159
If my research was correct EBC also offer OE pads, Greenstuff and Redstuff pads. Also grooved discs etc.
  Clio RS 2003
So let me get this straight... so far, the parts needed are:
* Espace MK4 caliper (codes: 6284-2/6285-2) > can be found on the 2.2dci engine
* Espace MK3 pads (?)
* Scenic MK2 discs (300x24) > can be found on 2.0 and 2.0 turbo
So.. the pads from the MK3 espace are compatible?
  MX5 NC 2.0 Sport
You need the calipers of the mk3 espace, mine where from a 3.0 v6 but the dci should probably have the same.
Regarding the discs thats correct.
I cannot confirm the pads yet, i ordered them a few days ago and they are on its way now with delivery scheduled for friday (tomorrow).
But im pretty surtain that it should fit as there for the espace 3.0 v6 mk3 ;)
  Clio RS 2003
While talking to the local breakers, I received the same caliper code for the 2.2 or 3.0 dci MK4 Espace/GrandEspace.
  MX5 NC 2.0 Sport
If you guys want i can see if it fits with my spare tire (15" OZ f1) ?
I think you'll be pushing it with a 15". One with a strong offset might clear it, but with the weak offsets the Clios generally run then I doubt it.
Wheel design will also be key here, flat spokes are more likely to aid clearance than the concave designs.
  Silver Clio 172 Phase 1
Smokey if you could see if they fit under the 15" oz f1 that would be awesome! As i'm really interested in this but love my 15" oz's!
  MX5 NC 2.0 Sport
Ok will do, i have the standard oz f1 phase 1 spare tire. Good test because it got the most used offset on these cars.
  Clio 182
Some 15" wheels fit over the 308mm upgrade people put onto their Corsa Cs, all depends on the offset and design of the wheel.
Well fingers crossed the OZ's will be ok then!!
As i know Jamsport do a 295mm 4 pot kit thats fine under 15" speedlines / oz's with no spacers etc
  A3 2.0TFSI QUATTRO
Ill be looking to get the same setup if all is good and am running 16's so should be fine and ive already got prices from suppliers through work for calipers discs and pads to buy new
  172 cup
Might hold on putting on my new brembo discs and pads unitl I see if this works. Syko, how much is this this setup coming up as new?
  A3 2.0TFSI QUATTRO
Its only worth it new at my staff rate i recive as a normal trade its silly money
  MX5 NC 2.0 Sport
The discs an pads are realy doable might even be cheaper than the normal parts 172/182 here in the netherlands ... lol
I asked some scrap yards for the prices on some used scenic 300mm discs.
They where asking for more than i payed for my 2 brand new brembo discs :eek:
@syko6288
I'm realy curious how much 1 caliper would cost in the normal trade ..... must be insane
  Turbo 182 Alfa 159
If all is well used calipers will set me back 50 and another 50 for calipers refurbed via EBC which isn't too bad imo.
  A3 2.0TFSI QUATTRO
Calipers - £95 each
Pads - £25 set
Discs - £120 pair
Total new - £335
  A3 2.0TFSI QUATTRO
The ones through work are from a company called brake engineering but if im to be honest i would use georges pads and discs (brembo and cheaper for pair) and then calipers
  172 cup
Smokey do you know if the calipers from an grand espace rxe v6 auto are the correct ones to do this??
  MX5 NC 2.0 Sport
Those might be the same aswell yes, ask them if there 2 pots if so there is a 9/10 chance there the same.
But always compare the part numbers on the calipers (just to be sure).
pat-t2phy
  clio trophy
Are spacers required when fitting with 16in wheels or will there be enough clearance between wheel and caliper?
  MX5 NC 2.0 Sport
Thats all down to the offset of the wheel your using. I can shad some light on this after there mounted.
  phase 2 172
Liking the sounds of this upgrade. Will watch with interest. Might try and source some myself.
  MX5 NC 2.0 Sport
I can't wait to put them on tomorrow, assuming the courier delivers the goods on time (scheduled for today) .......
At one of the pistons on my calipers there was a small hole in the dustcover (rubber surrounding the cilinder) i assume this is no problem ?
Cleaned it and closed it with some a-grade kit.
Im not an expert at this but i tink the cover is mainly there to stop the dust from coming in and protect the seal, can someone confirm this ?
  A3 2.0TFSI QUATTRO
I think they are dust covers to protect the pistons but to make sure i would keep a close eye for leaks once all fitted
Rob
Got a picture of the seal? You can normally nick those of lots of different brakes and they fit. So maybe even take on off your current setup?
Oh and really very nice work with this, is about time someone found a bolt on brake upgrade, the 106 boys etc have been doing it forever and we've been stuck in the dark ages.
