Track/Race Suspension
GazzaCup
  Z4 Coupe & 182 Cup
What would you but if you had a £1200 budget
Race/Sprint use only
Ktec 750mc spec coilocers - looks like you get the harder springs required 740lb front and 450lb rear springs with Spax dampers
Gaz Golds or BC - looks like they come with much lower rated springs.
Do I go for the kit with the softer springs (for wet) and buy stiffer springs for dry?
Any help would be great.
pule333
  Clio 172, RS4 B7, A1
I had 750mc SPAX on mine. They were brilliant! Still not sure why I even upgraded to AST. Apart from them being softer see no difference yet.
Ads29
  Clio 172 Merc ML55
Gaz gold for me, I had 800lb on fronts and 450 rear, have subsequently reduced the front to 650 after fitting roll centre correction kit.
Cant fault them one bit to be fair, I had to have the new front springs custom made as I couldn't find anywhere to supply the spec I wanted but otherwise they're pretty damn good for what I need.
a17vts
  2005 RB 182 Cup
I've recently installed AST4100's on my Clio 182 used for the very same purpose. Prior to that I was running GAZ GHA's.
If you catch a supplier with a discount you can get 4100's within budget.
