Torsion Bar Drop
What drop has everybody got on there 16 valver torsio bars, with 35mm lowering on the front. Is 55mm too low and effect the handling+Braking
for the best in handling mate its better to have the rear end higher than the front (original manufacturers spec). Depends how you drive, if you just cruise everywhere then drop the rear as low as you want cos it certainly improves the looks of the valver(if thats possible!) Might also be an idea to adjust the brake bias.
pete
so the best way to keep the handling is only drop the back 35mm, which is the same as the front lowering springs. therefore it will keep the back higher than the front
