Throttle body help!
  Renault Clio 1.2 16v
Hi all, recently I have been having problems with my throttle body. So I took it to a renault specialist and they said that a new throttle body and the labouring costs would be about £500. Now I know that you can pick up second hand ones in good nick for about 70-100£ and I could fit it myself. My question is when the new throttle body has been attached will it work straight away or will it need to be out on a diagnostics machine to erase the fault?
​Any help is much appreciated. Thanks
  172 Cup & K20 Ph1
Wow 500 quid?! I'm not sure how different the 1200 engines are from the F4R but the throttle body can be changed in about 10 minutes, when I changed mine I didn't need to wipe any codes or anything, it worked straight away, although the code moved from a current to a stored code instead. I picked up a replacement throttle body for 35 quid.
  182 cup
the TB is replaced and will work straight away. my garage tried to charge me 35 for them to wipe the code, i just did it myself!
