Stereo Just died :( - help me
Just gone round a tight corner at tight spped and the standard equip stereo turned it self off.
It works but only when i press the power button and i have to turn it off again once i switch the engine off.
Any body know what the problem is?
Sounds to me as you have a bad earth or something... and the corner moved disrupted it!
Daz.
yes definately a dodgy earth of two speaker cables touching each other causing a short. Check all your connections including the ones on the back of the headunit. You should be able to find the source of your problem easily enough.
Russ
Evil I.C.E. Car Audio
