Some Brake Questions!
Martin_172
ok guys just had my 36k service, front pads 90% worn, rear disks 100% worn lol not to great!!
so been thinking greenstuff front pads, new standard rear disks and braided lines with a fluid change. had standard front disks put on it before i picked it up when i baught it so they are fine and rear pads were brand new too.
so just need some opinions on what fluid to use (and how much do i need)?
Are braided hoses worth it?
i know some here dont like the green stuff pads but i rate them from my old 1.2, maby not the best pad in the world but low brake dust is great since im a clean freak!!
Castrol super dot 4 response.
Worth it if doing a bleed and want/can afford the extra.
I'd not bother with green stuff.
  BMW M135i
Deffo go for the castrol super responce, its only a tenner from opie oils with the CS discount and was/is a quite big difference between it and normal dot 4 stuff.
I've got brembo hc discs/greenstuff pads/goodridge lines and can't fault them, definite improvement over standard.
