Got a really annoying issue on my ph1 172 When starting from cold it has a big hesitation at low revs and pops and bangs from the exhaust very loudly on the over run and when changing gear. This lasts for 5-10 mins and then after that runs and drives perfect! If i leave it to idle i can almost hear the point of when it clears and runs better.
I have a decat fitted with both lambda sensor connected also a itg maxogen .
Ive already changed-
thermostat
coolant temp sensor
map sensor
lambda sensor before cat
all using either genuine or best after market parts. ive plugged it in on numerous occasions only to fine lambda sensor fault (after cat) which i think is due to decat..
Any help would be greatly appreciated
thermostat
coolant temp sensor
map sensor
