Quote: Originally posted by ian172 on 17 February 2005
they are 19.95 from blackspot with next day delivey. u only need a 2meter length if u read the mounting instructions is says mount it on the black checkerd bit behind ur rear view mirror on the inside of the screen as this bit is not uv.
i mounted mine down in the non uv patch at the bottom of the screen works fine, full signal. just loose the access cable between the dash and windscreen
Cause the uploader is no more!!Quote: Originally posted by Gambler on 24 March 2005
any idea why the pics are not showing up on my screen?
cheers
