right im fedup with this flippin knocking
  53 Clio's & counting
right guys you gotta help me here
i get a knocking noise mainly in first, when the wheels scrabble for grip ie when pulling fast out of a junction. is does it when in a straight line,also when turning, its like a loud knocking,thudding noise, and also the engine feels loose,as if the mounts were worn.
now i thought this originally,so i bought an uprated dog bone mount from hill power, then a new top mount (the one that bolts to the inner wing) and the gearbox mount under the battery brand new from reanult,and the nalso the rubber block that bolts between the bottom of the box to the subframe, now this improved slightly but not fixed. coming off and on throttle at low revs you can feel the engine moving about also.
now i have adjusted the mounts as suggested on here, ie the top mount was undone and engine pulled as forward as possible and done bk up, the bracket for the dog bone i have undone and adjusted as per instructions on here, so i have done as much as i can
and the movement and knocking is still here,now i have had people tell me the engine should move around a little,but it is moving too much i think, in fact so much it has now cracked my exhaust at the joint of the middle box to cat
so i know this is not normal, so is there something i have forgotten? can the mounts be adjusted any other way? or do i have to buy uprated mounts? is there a specialist i can take it to? (im in wiltshire,anywhere close?) i just cant see how it can be like this as standard, as im sure other peoples cant be moving and banging enough to crack your exhausts guys?
pls help guys im at me wits end now
thanks
russ
  A4 DTM/iceberg cup
standard exhaust??? i have an aftermarket one and im not quite sure the fit is spot on yet. had all the mounts sorted and still does the noise in first and sometimes second on a bumpy surface. at a loose end myself and running out of options. something must be adjustable......
Daniel
  Whichever has fuel
My old phase 1 did the same. Replaced EVERYTHING! Still does it to this day!
nope blueflame cat bk mate,but did it with the std one on too
exaclt mate,mine in the wet is really really bad,and the engine movement is still too much i swear
also if you hold my brake on and bring the clutch up to biting point again and again you can feel the engine moving around,like its slightly loose even
there must be something iv missed?
lemonnobby
one thing to is check how close the exhaust manifold to the sub frame. they are very close. if so we have had to raise some of them up at work. Ph1s are a bit of a nightmare the rest seem of i had the knock on mine 2 mounts and its all fixed. also check the stud is tight in the gearbox mount
done that,stud is tight as far as i can tell,though the mount does look like it moves a bit when grabing the engine to rock it by hand
exhaust is close but doesnt knock as there are no marks on the exhaust or the subframe
lemonnobby
thats me out of ideas what about raiseing it up at the gear box end any way.
without hearing it its very hard to say
il give this a try mate il let you know how i get on
im also going to try a std dog bone mount,has anyone got a std ph1 172 dog bone mount? im happy with it in any condition,i need to try something!
right i cant bloody believe it!!!
i thought i would try to fit the washers under the box mount tonight,but i ran out of time,alli have done it undone the two bolts on the mount,not the main big one, so i tightened them back up, put my battery back on and came over to the house that me and thre other half are house sitting at and the movement is worse and when i accellerate hard in 1st i get a wherring(sp) grinding noise!!! the only thing i can think now is the engine is moving so much a part of it must be sat against something and vibrating like mad,but i cant see how as alli did was undoo those two bolts then do them back up!?
  Meg 230 R26 F1
i had knocking in my ph1 172...coming from the front/engine area.
turned out to be the ball joint on the passenger side...yours sounds alot more serious, but i took mine over to bucks renault and they sorted it out a treat...turned out i also had a crack in one of the springs.
highly recommend the garage if you dont mind travelling a few miles
thanks mate the ball joints are spot on, and springs are new
any other ideas guys? i cant see how mw undooing and tightening those bolts could have done anything? :(
  SQ5
Got my powerflex dogbone moount coming early next week, your welcome to mine if the mount comes aswell as the bushes :)
well im trying to sort something out by sat as i can steal a ramp @ work but if i can still have that off ya mate it would be great :)
  A4 DTM/iceberg cup
still clueless myself. 1st gear knocking lol its turning into an ocd. will ask them to look again on monday whilst shes having a nice new clutch.... strange how they didnt do it new though.....cant get my head around it
  A4 DTM/iceberg cup
just keeping this thread alive incase a genius that has the answer stumbles across it and decides to post.
right well what im going to do is get it up on the ramps on sat, i will strip the mounts off and start again, and il take pics as i go,and hope to god i can solve it
lemonnobby
Is that what has been done to mine Paul? It has some washers under it. Absolultely spot on mine is
Yes thats right i belive every mount on that car was fiited new by me and that mod was made.
Russ may have moved a bit but i but the exhaust is on the subframe.
so if i have managed to adjust the mounts wrong, when adjusted will engine movement be reduced? as it gives the feeling of shagged mounts atm
Update:
right got it up on a ramp at work and undone all mounts, including the mount that is on the block that the dog bone bolts to,battery out and gearbox mount off
found the stud that runs up through the g/box mount had worked a lil loose so that was tightened up, the dogbone bracket was adjusted as per on here, and i put washers on the g/box mount under the battery to lift that up slightly.
then i took the top one off and put it in the vice to crimp it up slightly
results:
the engine now moves less, which is nice,no more knocking under acceration
but
when loosing grip in the wet/dry it still sends off a bloody knocking noise!
now i know it cant be me as everything is now checked and double checked,my last hope is to fit a std dog bone mount i guess
  BMW F31
when you say you loose grip you get a knocking noise, is it more like a bang from one or both of the wheel areas?
also is your car lowered? if so on springs or shocks?
the only reason i ask is that the shocks could be knackered as they will not rebound properly and will bang when you loose grip. without actually being in the car when it does it though makes it very difficult to diagnose it.
lemonnobby
i said about that stud didnt i?
There is some banging to a degree its called axle tramp.
But i would ft a standard dog bone mount
good point bud but shocks are brand new with eibach prolines,and did this before with the old shockers thank you tho :)
yup im suprised it had worked loose i did that up TIGHT
so on the look out for a standard dog bone as you suggest buddy pls pm me if anyone has one
thank you once again for the helps guys
still knocks if i launch fairly fast of the line mate and in wet conditions :( alot better dont get me wrong but its still there i dont know what to do
has anyone said top of the struts...? Saw a thread while back saying they sometimes bang against the top of the bonnet under hard acceleration...
thank you for helping matey i thought this possibly too but alas the strut tops and bearings are new and still the noise stays
Ahh ok no worries
Have you managed to pin point where abouts the noise is coming from? which side of the car? both? near the wheels etc
both sides matey, depending which ay the wheels are turning (even slight turning can cause the noise to change sides)
its coming from the front,and sounds like the engine knocking against something
