Removing back seats
How hard is it to remove them on the new uns as i could do with losing a bit for some weekend thrills?
-Rob
It cant be that hard, theres normally a few brackets screwed onto the base, should be simple! Why? U wanna get light for a weekend raggin?
its just unclips......
bench is easy to get off and the backrest needs a few clips to be undone.
  Lionel Richie
You need to remove the two 17mm bolts that hold down the rear plastic bit, the youll see a bolt inbetween where the two seats split, undo this then your done!!!
