Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
You need an 8mm allen key to jam up the hole in the back of the steering wheel. This pushes up on a clip to release the bottom of the airbag. The top 2 corners just pull out.
If the airbag hasn't been off before you will need to make your own hole in the airbag (where the indent is)
Once the airbag is out you'll need a T50 torx bit to remove the steering wheel bolt (these are a one use only bolt - although I didn't replace mine )
You know whats next lol....how do you remove the horn fuse, pull out the relevant fuse from the fuse tray @ low level? I need to make sure i get the right one as i dont want the airbag going off lol.
