Clio 1.4 16v 53'
Tonight I was driving home, in 5th gear and went to change down to 4th. When I did, instead of the usual silky-smooth change straight down to 4th, I hit resistance and had to go accross and down as I suspect you would normally. I have no problems going into 5th, just down to 4th. I changed as often as I could following this to make sure and it did the same thing each and every time. I have no problem moving to 4th in this way, it's just that I've never had to do this before.
I remember by driving instructor's car doing the same thing.
Should I be worried, or does something probably just need adjusting?
In my experience and everyone I've talked to in the past, gearboxes are only second to engines in expense .
