given i have a cnc mill, im hoping mounting wouldnt be an issue. i can machine what ever i needYes, there should be plenty of options, the main potential difficulty is in mounting the cooler to what you want to cool and getting good thermal contact.
Is it something which could be immersed in water? Or something non-conducive like mineral oil?
are you referring to something like this?A 280mm or 360mm AIO liquid cooler would be able to handle 300W, assuming you can attach it somehow
do they NEED a pwm signal?Yup those, or a Corsair H100 or similar. Generally fed by power, ground, pwm signal and often have a speed sense output.
I’m not sure tbh, I’ve never tried. Basic fans will just run on 12v but I think the pump might not?do they NEED a pwm signal?
ok, something i may have to deal with then.I’m not sure tbh, I’ve never tried. Basic fans will just run on 12v but I think the pump might not?
Whilst I love thorlabs, they sell the stuff dreams are made of. I cannot afford their equipment.Don't you want a liquid cooled diode mount?
Like this, but bigger?
na thats just a toy, mine is way more powerfulDragonFire: UK laser could be used against Russian drones on Ukraine front line
The defence secretary said the laser could be used to take down Russian drones as early as 2027.www.bbc.co.uk
This what you're needing to cool?
