Pug 206 SW, 172 CUP
Just a couple of questions. I've been using the search function, scoured the net and read the various clio manuals but can't find the answers i was after!
1) When the Injection system on a clio 182 goes into open loop is it just the Lambda sensor it ignores or is it the MAP sensor as well? Are there any other sensors it ignores?
I'm fine with the way injection systems work but each manufacturer has their own way of doing things and it's helps to find faults etc if i know how it works.
2) Also is 6500rpm definitely the engine speed the cam timing backs off again as i have seen 6800rpm mentioned elsewhere.
3) And finally does anyone know the richest air/fuel ratio or %CO the standard map uses.
Thanks.
Thanks.
