182 FF
Found a few drips under the car, seems i have a bad leak. Recently changed the dephaser and think that i may have damaged the cam seal on re-assembly
However i am having some trouble deciding where its sourced. The leak was most obvious at the bottom rear corner of the cam cover plate and down the side of the block.
I have dissasembled the timing covers and found a lot of oil on the plastic cover and a fair bit on the inside edge of the cam sprocket cover, the engine mount also had a fair coating.
I am thinking dephaser cam seal, but am confused at the lack of fresh oil around he dephaser itself
Will oil leaking from here be pulled around the engine by the cambelt (which isnt totally soaked), or am i needing to look elsewhere?
the cam cover seal is A1
(pool of oil where finger is
