oh im running on 3 cylinders help
er for some reason im running on 3 cylinders, and no 1 cylinder is not working for some reason the plug is sparking, and the injectors are working hhmmmmmmmm what could it be please help!!
  Caddy Maxi
crap leads, buggered dizzy crap plugs! check the ignition system before having a compression test done as it may be just that and no HG failure
well if i take the plug out and connect it to the lead that goes to that cylinder it sparks fine
so it cant be the dizzy cap, and the lead works ok
while running i can take out the, no one lead and plug and its still which tells me something is happening in the cylinder
what else could it be, and is there any other tale tale signs of lack of compression!!
while running i can take out the, no one lead and plug and its still running as badly as it was before which tells me something is happening in that cylinder
  Caddy Maxi
try a different lead on it first mate (ie swap it with no 2 on both the dizzy and plug) to test it, of its still doing the same it looks like a compression issue
  MKIII 138
accelarator cable ? dunno why i said that, i had a fault exactly the same and they changed this cable or altered it and after that it worked fine
