Have a problem, it is very tight putting it into reverse at the mo. doesnt grind, is just tight. and there is a rumbling sound when i lift off the accelerator and am using the engine to brake. What is it?? anyone know gearbox, diff etc.
the reverse fault may be just your gear linkage is a bit stiff.lubricate the gearstick mechanism and all pivot points on the gear linkage.the noise may be a diff or shaft end bearing getting noisy.does it only do it on overun? does speed change the noise?
