I have a clio 2002 1.4 16v.. had slight pull/wobble when letting off the accelerator so changed the mounts.. now I have a light snake/wobble coming from the back end, when I hit a bump in the road or yellow warning strips the back end snakes a bit a bit like a trolley wheel feel (only happens in a straight line), has anybody had the same prob and know what the cause is? the bushes on the back end all look ok but both bottom arms on the front are shagged (could that be causing it?).. car is lowered about 90 on back.. thanks in advance.. :clown:
P.S had a good look around the car and cant find anything wrong appart from the bottom arms, had the back end in the air and no play on the back wheels etc, nothing wrong with the chassis or body etc
