How to mount amp to rear seats?
  Renault Clio 2003
Straight into the back of the seat? Obviously not?
I searched around and heard about using wood, but how would I do this?
Jack.
You would still need to secure the wood to the seat somehow.
What about making a false floor out of MDF, screw it onto floor.
  172 mk2
undo zip, secure a flat piece of wood to the seats with cables ties or something. zip up. drill through cloth into wood..
  172 mk2
undo the zip and you'll see. use a square flat piece of wood wide holes in each corner for the ties.
simples
I mounted it on the back of mine. I unzipped the cloth, but underneath wasn't a flat metal to screw to, its like metal struts horizontally and vertically.
Don't know if its different for sport rear seats though?
  Renault Clio 2003
Ok, managed to do it, drew around my amp and cut a bit of wood a little larger than the amp drilled a hole in each corner to cable tie to metal bits after unzipping seat, then screwed amp to wood, through the cloth!
Thanks everyone for the help and advice.
Jack.
