how old clio? really old clios you will have to remove the fuel tank as there is only a access hole in the floor for the sender unit but not the pump.clios with combined sender unit/fuel pump unit you just change it through an access hole in the floor under the rear seats.undo the large nut/ring.make sure the tank is as empty as possible and change the pump as quick as possible as the tanks can distort if the large nut/ring is left off for long periods of time(10mins+)
