Hello All.
You lot are basically going to decide for me what sort of AMP/SUB I should buy!
Firstly I know nothing about watts and channels etc so help me out!
OK, I have the below headunit, its a JVC KD-SHX701
http://erc.qmuc.ac.uk/cliosport/gallery/full/1102875020__jvc.jpg
A bit of info on it:
Power Output Per Channel:
50 W
Pre-amp Outputs:
3 sets
Pre-amp Output Voltage:
5 V
What can this system handle?
Right, I mostly listen to Hip Hop and RnB, so considering this what should I go for?
1x 10" sub?
2x 10" sub?
1x 12" sub?
2x 12" sub?
1x 15" sub?
I dont what a sub that is just pure noise, I would actually like to hear the words and everything else in a tune, but bass is obviously crucial!
If possible I would like to have a JVC amp and sub to keep the brand thing going but this is mandatory.
I have seen amps that have 2 channels and some that have 4 channels.
Whats the difference?
So lets say I have a sub that is 700W max and nominal 350W, what power amp should I buy? And if I have two subs at 700W max should the amp pwer be doubled?
Also is it dangerous to run subs at max or should it be kept within nominal?
Guys, sorry for all the questions, but Im sure I will learn as I go along and from your replies.
PS. They dont have to be JVC, so If you would like to recommend another brand sub and amp please do so! I will probably spend between £200 - £300.
Thanks all.
