guide to remove gearbox on 182?
  B/G 182 + PH1 Track
i would think its an engine out job??
well the lad that does the gear box on our track car has it so dialed now he can do it with out remoing the engine of the subframe, so it can be done. i wouldnt knoww where to start though
  330Ci Clubsport
used Bens guide there, pretty much spot on cheers!
Gearbox out and away to be inspected see what shape its in. One of the springs had broken off the pressure plate and made a right mess inside the bellhousing. No wonder I couldnt get gears!
  330i. E30 Touring.
Ouch!
The only thing missing from the guide was the subframe support arms (under the car) but common sense leads you to those straight away! I found the hardest part was lining up the new gearbox to go in!
  330Ci Clubsport
aye lol they caught me out as they were behind a bit of plastic. couldnt understand why the subframe wouldnt drop!!
182Trev
  Clio RS182
Just wondering if another guide exists or a new link to Ben's guide exists? cheers.
