Gaz Coilovers, £450 on eBay - any good?
  White ds3
iv got these one and orderd form this guy very good took a fiew wks but if you phone he anwers every time he even phones you to keep you up to date highly recomendid
  Ph1 172 & meg 225 lu
i have gaz on my ph1 and havent had any problems (touch wood)
you can buy better but thats always the case, there good enough to lower more than needed and have a reasonable ride quality,
ive had mine for 6 months and wouldnt change them for any others
oh yeah i have a number of someone who sells them for less than that
pm me if your interested ;)
DrR
  VW Golf GTD
Are these actually any good or they just for lowering freaks?
  2118'd Iceberg Ph2 172
Well these and others around this price range interest me, but I already have Koni dampers and springs (not sure whether adjustable or not), which seem to cost around the same as these coilovers from K Tec!!! So would I see a benefit? Are my Koni dampers and springs worth that much?? They came with the car, and seem ok. I need some new top mounts at the mo desperately though so may see what its like after I've replaced them this w/e.
  Corsa Van. Meh.
^^ where abouts in essex you from mate?
Your more than welcome to come and sample a ride in mine, I have FK's. Would give you an idea of what to expect.
I'm in Basildon, that would be superb, thanks!! Only just started to realise my top mounts are ruined, I reckon so much so that I'm actually getting some -ve camber for free!! There's knocking and squeaking etc too, so this w/e the top mounts are getting replaced, standard ones from GSF for now, solid ones later when I can afford. I'll do this first then it'd be really good to compare, thanks ClioTurbo_1. :D
  Corsa Van. Meh.
I'm only in Billericay so give me a shout!
Matt
Gaz_
  Extreme mode
Utter dross GAZ. Been there done that..... buy cheap buy twice (i did :()
Gaz_
  Extreme mode
Its not abuse. I have had the misfortune. I have substance to back up my rantings about how w**k they are lol.
  Porsche Boxster987S
what exactly is so bad with the GAZ setup? im curious cause im either going to fork out for these or just get sportlines
Ditto, tbh I'm getting to the point where I don't bother replying to most of the posts. People clearly can't use the search function. Put bluntly they're cack.
They have adjustment but you only have 2 choices no matter how many clicks you go in either direction, bouncy or boneshaker. They knock rattle, squeek, clunk and generally make the handling worse than a £90 set of apex springs. That sum it up enough for you?
Gaz_
  Extreme mode
If you want noisy, pogo stick handling, then go for it ;)
They ruin what the Clio is good at................... handling ;)
Gaz_
  Extreme mode
They have adjustment but you only have 2 choices no matter how many clicks you go in either direction, bouncy or boneshaker. They knock rattle, squeek, clunk and knock and generally make the handling worse than a £90 set of apex springs. That sum it up enough for you?
The scars are deep, and still raw :(
DrR
  VW Golf GTD
I want some coilovers, just can't justify spending so much on H&Rs, them or standard IMO
Gaz_
  Extreme mode
I'd be inclined to fit some Koni/bilstein dampers with Ebaich sport lines. They'd be 100% better than cheap coilovers. I had some Prolines fitted to my Cup before the GAZ Coilovers. Really rated them. Just didnt give the drop i wanted.
Gaz_
  Extreme mode
Ask Kev what he thought about them on my Cup ;) Keep a look on ebay. I sourced a second hand set of H&R's for my 182 on here, then sold them to Guppy :)
Biggest waste of money I think I've ever had the misfortune of owning on a car. And I had a set of 17's on my 172 at one point :eek: if only I knew! lol
PMSL!!!
  Porsche Boxster987S
by doing this would it go lower?
Gaz_
  Extreme mode
Proline - hardly...... Sportline - 30mm iirc (might be the other way round?)
  Porsche Boxster987S
sportlines lower it more , i know that. just didnt understand what you meant about dampners or that. im pretty dumb when it comes to this kind of thing
Gaz_
  Extreme mode
The dampers will be shorter, therefore better. But imo, you'd be fine putting the sportlines on your car, with the Renault dampers. Ebaich are a quality spring. Will feel a wee bit tighter than the Cup set up, but not too hard or crashy like the Apex.
  Porsche Boxster987S
ok so you'd say i wouldnt make the handling worse by fitting sportlines?? I
Da
  Less
I have sportlines on mine, there is a difference in ride quality but it's minimal.
Funny you should say that, just try searching "gaz". Nothing comes up.
got mine for xmas, they are ace, just deciding what dampers to go with now. the ride is a little firmer, the drop is good for me, makes my 16s fill the arches better, and the handling is improved, they are great imo.
  Clio MK 4
my dilemma is like most on here.
most likely going to get sportlines due to them being cheaper than collies but i know i will want lower
Craig
  E46 330i tourer
i had sportlines but wanted coilvers so was looking at the gaz but i didnt want to waste all that money and be dissapointed but luckily for me i got some mega cheap H&Rs
