Front pads and discs gone!
  Yozza'd Titanium 182
Heard the dreaded noise when your pads go :(
I changed my rear discs and pads a few months back and I'm just basically wondering if it's exactly the same principle.
I'm considering just taking it to the garage.
Are the discs different on a cup?
Mine is a 182 non cup
DrR
  VW Golf GTD
You know if you don't wait until your brake pad wears down to the metal the discs last longer than one set of brake pads?
  182
Same principle, wheel off, unbolt calipers(tie up out of way), swap discs, remove pads, push piston back(fronts don't wind back like the rears), put new pads in, slip calipers over discs and bolt back up, wheel on, job done.
Discs + pads are the same.
