Fog lights install on pov clio.
  Rs200
hi again
also got some fogs but i need to wire them in am i right in using a simple circuit? just earth them out in the chassis? then connect both positive wires into a switch then run the positive from the switch to an inline fuse and attach to th battery? cheers
  SQ5
Easy way would be to get the bit of loom as you will have a plug there ready to connect to and get a stalk from a model with fogs.
You don't need front fogs though in all honesty just look nicer in but not working.
  Rs200
i havent actually had a look yet cars on gf's drive. ill get the arch off tomorow maybe and have a butchers as this seems safer then my mr bean wiring
