Followed the correct bleed procedure farthest first etc. But maybe not level ground, kept res.full but I now have spongy brakes and a creaky pedal. Sounds like air- my biggest fear!
Battery on charge now back to the bleeding, I can hear creaking in the lines at the rear(possibly air?) But it won't come out. Put near to a litre of ATE super blue in now.
One other thing should the reservoir be touching the back of the engine block? It has to be pushed back to even get the top off
Dragging this up again since I tried an easybleed but don't seem to be getting any air out. With ignition off I get a good solid pedal not so good with it on and a slight grumble noise right at the top of the pedal travel, (I'm presuming this to be air?) after that though the braking seems to be not so bad in use. I've heard people saying to pump the pedal and easybleed at the same time is this going to solve it?
