Clio 200 | Front Camber Adjustment
  Clio 200
I think this one might have come up before...
How can the camber be adjusted on the front of an RS Clio 200?
There are the odd sites selling 'clio 200 camber bolts' - but they just look like the universal powerflex items ( here).
It does say "This fits 2 bolt hub to strut models only" - whether that's a generic term for the universal-ness of these or specifically the clio 197/200 (later/earlier models?).
If these are (likely) no good; I believe the other options are:
- An adjustable front arm bush
- Top mounts?
  monaco 172
How much camber you wanting? If the 200 uses the same sort of strut as the 172 then you just replace the top bolt with a camber bolt and slacken the lower bolt, set desired camber and tighten up.
There's a tiny bit of adjustment available with the standard bolts but only a mm or so either way.
